Short cycling of compressor when temperature is set to more than lowest?
2012 FORD FIESTA
75,000 MILES • 1.5L • 4 CYL • TURBO • 2WD • MANUAL
ARAVINTH5992
Initially the A/C was blowing hot air in standstill and cold air only when moving. The culprit is the radiator fan, and it has been changed. the compressor pressure switch blown off, so changed that as well.
Now topped it up with r134a after vacuuming and checked for leaks in the system. No such issues.
Now
1. Ac blows cold air only at "Lo" setting, starts to emit semi hot air even if changed to 16 deg Celsius.
2. Compressor short cycling when i set to 16 deg or higher. Works continuously in Lo setting.
Please share some light on this.
Dec 20, 2023 at 11:28 AM
It sounds like you may have a bad compressor, or the expansion valve is clogged/bad. We need to connect a gauge set to help us see the pressures when the system is running.
This video and guide can help us see what's going on:
https://www.2carpros.com/articles/how-a-car-air-conditioner-works
and
https://youtu.be/4EqdrBVb0sY?si=onXONmZhXGU8NYzT
Please upload pictures or videos of the problem so we can see what's going on.
Dec 21, 2023 at 2:09 PM
ARAVINTH5992
Thanks for the inputs. Let me get the actual data of my vehicle and we will proceed from there.
Dec 21, 2023 at 11:53 PM
Sounds good, this will help us pinpoint the problem so as don't go in the wrong direction and waste time.
Dec 23, 2023 at 9:52 AM
