Shocking sensor
2000 PEUGEOT 406
37 MILES • 0.5L • 4 CYL • 2WD • MANUAL
MAKANAKI7
  • 18 POSTS
The motor didn't shock what can happen to it I need video
Jun 14, 2022 at 7:12 AM
I am not sure I understand what the issue is. I am not sure what a shocking sensor is or what you mean by the motor didn't shock.
Does this mean the engine is not starting?
If so, here are a couple guides that will help with this:
https://www.2carpros.com/articles/car-not-running-advanced
https://www.2carpros.com/articles/starter-not-working-repair
Unfortunately, we don't have a manual on this vehicle so we are going to have to rely on generic information but let me know what the details are on this, and I will see how we can help.
Thanks
Jun 16, 2022 at 12:28 PM
MAKANAKI7
  • 18 POSTS
I mean the motor did not start.
Jun 16, 2022 at 12:37 PM
Okay. Then the guides I supplied are going to help get us started.
Basically, we need fuel, air, spark, and compression to start an engine.
So, we need to find out which we do not have.
This is assuming that the engine will crank over but just not start. Or does the engine not even try to start when you turn the key?
Jun 16, 2022 at 12:43 PM
MAKANAKI7
  • 18 POSTS
It doesn't spark.
Jun 16, 2022 at 12:46 PM
Okay. Unfortunately, we don't have a manual on this vehicle as it is not offered in the USA but if you have no spark then we need to start with checking fuses for the ignition system.
Make sure any security system that there is on the vehicle is not active. Normally there is an indicator on the dash that will show that it is on. When starting the engine this should be off.
However, the most common cause of no spark is a crank sensor that has failed. Again, I will not be able to tell you where this is on the vehicle as we don't have a manual but here are some guides that will help with this:
Please run through this and let us know what you find.
Thanks
Jun 16, 2022 at 12:53 PM
MAKANAKI7
  • 18 POSTS
Okay.
Jun 16, 2022 at 12:59 PM
