Vehicle has a shimmy/shutter when in any gear. (Drive, Neutral, Reverse). Mostly feel it when stopped at light in drive with slight RPM drop. Tends to have issues when driving deciding which gear to be in around 45 -50 MPH. Have sprayed engine with brake fluid to look for vacuum leak. Doesn’t seem to have one. Air Filter looks clean. Have tried clearing the computer with the jumping the positive battery post to disconnect ground for 20 + minutes. Looking to see what the issue could be.
The vehicle listed above is an XLT.
Replaced following parts with OEM Motorcraft:
· Spark plugs
· Injection coils
· Throttle body
· Mass airflow sensor
· Intake air temperature sensor
· Evp purge valve
· Spark plugs
· Injection coils
· Throttle body
· Evp purge valve
Jun 17, 2024 at 6:05 PM
