The car was hesitating shifting gears. Once it shifted it would remain in the gear and downshifting was fine. I changed the fluid, added Lucas Transfix, actuator spring was broken in two. I replaced actuator spring, put new governor pressure solenoid and new sensor solenoid, new filter, added ATF+4 fluid. Now it shifts up normally but then drops back to lower gear. it cycles 1 to 2 and 2 to 1 and 1 to 2 etc. If I accelerate it will shift to 3 and then slip to neutral. My thoughts are one of the replacement parts is bad. Any help is greatly appreciated.
The vehicle listed above is a Laredo 4L 42RE transmission.
Feb 6, 2022 at 11:33 AM
