Shifting problem from first to second gear
2005 FORD FREESTAR
150,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
MEL.CLARK
My van builds up rpm's in first. Gear some times it will not shift to second. For a second or two. What could it be?
Sep 30, 2018 at 2:36 PM
Good morning.
The throttle position sensor on the throttle body is what controls shifting of the transmission. When it fails, it usually sets a code.
Do you have any codes set in the system?
When was the last time the fluid and filter has been changed?
https://www.2carpros.com/articles/automatic-transmission-problems
Oct 1, 2018 at 4:36 AM
