shifting problem Code P0300
2004 GMC C2500
365,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
I KNOW
HD 2500. the engine light is flashing when I drive it down the road, but when I have it parked and the engine running then the light is on continuously and it is giving a P0300 code. I have replaced spark plugs and wires no difference. it also has problems shifting since the engine light started flashing, the torque converter does not lock up anymore since the light is flashing. i already changed the torque converter, but it did not help.
Jan 10, 2017 at 3:45 PM
STEVE W.
  • 15,113 POSTS
P0300 = Random multiple misfires. Can be caused by a lot of things, usually not plugs/wires though, those will set a code for the particular plug or wire that is bad. It is caused by something that controls all the cylinders. Bad coil, MAF sensor out of range, O2 sensors reporting incorrect data, even something like an exhaust leak at the manifold can cause it.
Run a fuel pressure test to see if you have low pressure. Should have 55-62 psi.
Check for a vacuum leak.
If you have access to a scan tool that will read live data check the fuel trim numbers both short and long term, and the O2 sensor response.
Jan 10, 2017 at 5:12 PM
I KNOW
Thanks for the advice Steve. I guess the next thing is checking for vacuum leaks. I already did fuel pressure it is about 60 psi.
Jan 10, 2017 at 8:43 PM
STEVE W.
  • 15,113 POSTS
That should be a good pressure. Individual misfires are much easier than the 300 code. Those at least narrow it down some.
Jan 10, 2017 at 9:07 PM
