Shifting problem
2000 MERCURY COUGAR
297,400 MILES • 2.0L • 4 CYL • FWD • MANUAL
CODY SANFORD 1219
When I was driving my car started jerking losing power and would not shift or go in any gear. What could the problem be?
Oct 15, 2017 at 6:12 AM
MHPAUTOS
  • 31,937 POSTS
You need to investigate transmission oil for level and quality first, any leaks from the transmission? Can you get a live data read or code check on the transmission? we do need some more information to try and isolate this problem.
Oct 15, 2017 at 3:58 PM
CODY SANFORD 1219
I just got the car back home it was on the side of highway, but i have not seen any leaks. When i started it and put it in gear it did go kind of dogging a little at first but got a bit better. I was thinking something was wrong with transmission, but now i kind of think maybe it is a filter problem or the fuel pump. There was not any grinding or anything either. What is your opinion on it? i am hoping that is what is wrong with it.
Oct 15, 2017 at 10:43 PM
MHPAUTOS
  • 31,937 POSTS
well, start with the engine tune if you feel that it is not transmission related. do a fuel pressure test and replace the filter. check for codes as well and post back what your findings are for further assistance.
Oct 15, 2017 at 10:57 PM
