Shifting issues
1998 FORD ESCORT
120,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
THERONVAREC84
I am having problems getting my five speed into mainly first, second, and fifth gears and sometimes even reverse. Can someone please give me an idea of what might need to be fixed and maybe how much also it will cost me?
Jul 21, 2018 at 12:24 AM
Yes, it sounds like the clutch disc is falling apart which means the clutch will need to be replaced. Here is a video that will give you an idea of what you are in for when doing the job:
https://youtu.be/6N6b5F2ChyE
Jul 22, 2018 at 12:40 PM
THERONVAREC84
Replaced the clutch already, it has to do with the linkage or cables I believe sir.
Jul 22, 2018 at 12:42 PM
That could be as well. Here is the shift linkage diagrams to help you replace the shift rod which the bushings can wear to in.
Jul 23, 2018 at 9:40 AM
