Yea, my check engine light came back on. I have not gone to get the codes checked, but every time I get them checked it is the same codes; P0700, P0716, and P0717 and I have replaced all of the sensors. Previously I have replaced the throttle body with sensor, the transmission input sensor, and I replaced the gas pedal with sensor and I also replaced the connectors to the sensors in case of wiring going bad. I unplug the battery when I work on it, so the codes clear and it drives better for a short amount of time but then starts shifting hard again and throws the same codes. So I'm thinking at this point it would be the transmission control module?
Nov 4, 2019 at 12:38 PM
