Light goes off if driven super carefully, not rushing...
This has been going on for a month. We had pressure sensor issue, fixed.Then oil change where a experienced recommended mechanic added our transmission additive with the oil (instead of oil additive) instead of putting it with transmission fluid. He just told us *I added that bottle (one of 2 he was given, but wrong one!) to the oil." As if he had done nothing wrong. He handed us back the oil additive.
So, we know we need completely fresh oil (blend) and work done.
The car seems fine and can drive fine but when it takes corners when accelerating, it is more sensitive. Going up hills, it often requires one to take all pressure off gas pedal until it drops a gear down.. then it gets right gear or whatever. ..then acceleration slowly is fine a little.
Like at top of each gear range it gets... shaky, sometimes it drops in; sometimes we must let it stay in lower gear until it accepts it.
If this is some protection mode!! It is ineffective since everything still basically works except cruise control.
The engine light has stayed off for days if we simply go under speed limit generally, super gentle acceleration, and watch the rpm's.
?? Could it be a pressure sensor? Hopefully husband will be able to answer your next questions. He's worked and now asleep.
Thank you for your time and consideration.
Lisa and Paul
Jan 11, 2020 at 6:52 AM
