It doesn't have to do with a shift solenoid. What determines the indicator's selection is called a transmission range sensor. It is located in the transmission. Chances are it is going bad.
___________________________
Here are the directions for replacing it. The attached pics below correlate with the directions.
2004 Chrysler Truck PT Cruiser L4-2.4L Turbo VIN G
Procedures
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Transmission Position Sensor/Switch Service and Repair Procedures
PROCEDURES
TRANSMISSION RANGE SENSOR
REMOVAL
The valve body assembly must be removed to gain access to and replace the transmission range sensor.
1. Disconnect the battery cables.
pic 1
2. Remove air cleaner assembly (Fig. 336).
pic 2
3. Remove the battery hold down clamp and remove the battery (Fig. 337).
pic 3
4. Remove the battery tray (Fig. 338).
pic 4
5. Disconnect gearshift cable from manual valve lever (Fig. 339).
6. Remove manual valve lever.
7. Disconnect transmission range sensor connector.
8. Hoist vehicle.
pic 5
9. Remove oil pan bolts (Fig. 340).
pic 6
10. Remove oil pan (Fig. 341).
pic 7
11. Remove oil filter (Fig. 342).
pic 8
12. Remove the valve body-to-transaxle case bolts (Fig. 343).
NOTE: To ease removal of the valve body, turn the manual valve lever fully clockwise to low or first gear.
pic 9
pic 10
13. Remove park rod rollers from guide bracket and remove valve body from transaxle (Fig. 344) (Fig. 345).
CAUTION: The valve body manual shaft pilot may distort and bind the manual valve if the valve body is mishandled or dropped.
pic 11
14. Remove manual shaft seal (Fig. 346).
pic 12
15. Remove TRS retaining screw (Fig. 347).
pic 13
16. Slide Transmission Range Sensor up the manual shaft and remove (Fig. 348).
INSTALLATION
1. Install transmission range sensor (Fig. 348).
2. Tighten retaining screw (Fig. 347) to 5 Nm (45 inch lbs.).
3. Install manual shaft seal (Fig. 346).
4. Guide park rod rollers into guide bracket while installing valve body to the transaxle case (Fig. 344) (Fig. 345).
5. Install the valve body-to-case bolts (Fig. 343)and torque to 12 Nm (105 inch lbs.).
6. Install the oil filter (Fig. 342). Inspect the O-ring for damage and replace as necessary.
7. Install an 1/8 inch bead of RTV as shown in (Fig. 341)and install pan to case.
8. Install oil pan bolts (Fig. 340) and torque to 19 Nm (165 inch lbs.) torque.
9. Lower vehicle.
10. Connect transmission range sensor connector.
11. Install manual valve lever to manual valve.
12. Install gear shift cable to manual valve lever (Fig. 339).
13. Install the battery tray (Fig. 338).
14. Install the battery and hold down clamp (Fig. 337).
15. Install air cleaner assembly (Fig. 336).
16. Connect battery cables.
17. Fill transaxle with ATF +4 (Automatic Transmission Fluid-Type 9602).
I hope this helps. Let me know if you have other questions.
Take care and God Bless,
Mar 3, 2021 at 8:43 PM
