Yes, the check engine light is on. But i do not know the codes . And i cannot get to an auto shop to run it for codes. Also, the fluid is full and i replaced a torque converter, transmission control solenoid, and speed sensor.
Mar 20, 2019 at 4:18 PM
CERTIFIED EXPERT
Got it.
I need the codes to help narrow the area of failure.
You replaced the torque converter already?
Mar 20, 2019 at 4:28 PM
NESHA22!!
MEMBER
Yes, the torque converter, speed sensor solenoid , transmission control solenoid , and The position speed sensor has all been replaced . When i was able to drive it to the part store , i believe the code was 1715 however since all those parts have been changed out. I do not know what codes are popping up now.
Mar 20, 2019 at 4:38 PM
CERTIFIED EXPERT
Okay, question.
Why did you not replace the clutches and steels inside the transmission when you had it out of the car?
Image (Click to enlarge)
Mar 20, 2019 at 4:45 PM
NESHA22!!
MEMBER
No one mentioned either. I have no clue about vehicles.
Mar 20, 2019 at 4:56 PM
CERTIFIED EXPERT
Okay, you stated two times you replaced the torque converter. That is internal in the transmission.
I assume you mean the solenoid.
Did you change the oil/filter in the transmission?
Mar 20, 2019 at 4:59 PM
NESHA22!!
MEMBER
Yes, it was changed.
Mar 20, 2019 at 5:14 PM
CERTIFIED EXPERT
Okay, we are back to the codes. You may need to have someone bring a code reader to you to pull the codes.
Mar 20, 2019 at 5:17 PM
NESHA22!!
MEMBER
I have one it keeps saying error.
Mar 20, 2019 at 5:22 PM
CERTIFIED EXPERT
I wish I could help more but I have no information to work with except you replaced parts and I do not know why.
I think you should have it towed somewhere and have someone diagnose it for you.
Mar 20, 2019 at 5:27 PM
NESHA22!!
MEMBER
Thanks for your advice. i thought maybe something was wrong with the computer because i have a code reader and it keeps saying error, but when i put it on my other vehicle it works.
Mar 20, 2019 at 5:51 PM
CERTIFIED EXPERT
I understand. It is hard from here to try to help without seeing it, touching it and physically checking it myself.
