Once put in gear it does not shift to next gear. I have changed the transmission and transfer case three times same reaction. need your advise!
Oct 15, 2017 at 3:35 PM
STEVE W.
CERTIFIED EXPERT
The power train control module operates both the engine and transmission. I would check to see if the wiring to the transmission is okay. Check all fuses. If they all look good I would suspect the PCM is bad.
