Shifting
2011 CHEVROLET COLORADO
112,000 MILES • 2.9L • 4 CYL • RWD • AUTOMATIC
JO A. HUTCHISON STILLWELL
  • 5 POSTS
The transmission does not want to shift. The rpm's will be about 3500 and shift, if I let off the gas it would shift sometimes too. We went to a parts store they suggested we replace the variable speed sensor. We did, but it still will not shift correctly.
May 13, 2016 at 4:52 PM
SATURNTECH9
  • 30,869 POSTS
So the truck does not shift till you let up on the gas some?
May 16, 2016 at 9:42 AM
  • 5 POSTS
Correct. We are going to try changing the filter and fluid.
May 16, 2016 at 1:54 PM
SATURNTECH9
  • 30,869 POSTS
Then I would go to a exhaust shop and have them do a back pressure test.If you have a restriction in the catalytic converter that can cause that to happen. Really doubt a transmission service will do much for the problem your having. Have you checked for codes in the computer yet?
May 16, 2016 at 2:41 PM
  • 5 POSTS
No I do not have a computer to do that nor the money to have it checked.
May 16, 2016 at 2:43 PM
  • 5 POSTS
No don't. Have a computer to do that nor money to have it checked.
SATURNTECH9
  • 30,869 POSTS
What state do you live in? also has your check engine light come on with the engine running?
May 16, 2016 at 2:59 PM
  • 5 POSTS
Tennessee. And no the light does not come on.
May 16, 2016 at 3:02 PM
SATURNTECH9
  • 30,869 POSTS
They do not do the free code reads at the auto parts store in your state? I know in California they no longer do. Also have the back pressure test done there is a good chance that is the cause.
May 16, 2016 at 3:05 PM
