My car has been stuck between reverse and neutral.
I used the shift override to get it into neutral, so I could start the car, but it will not go into drive. It shifts into reverse and neutral as long as I use the shift override, but will not shift into park or drive.
I plan on replacing the shift interlock solenoid and the stop light switch, tomorrow August 3.
Are these two things the most likely cause?
Even with the override, the shifter is extremely difficult to move.
Is there anything else that is more likely to cause these symptoms than the solenoid and stop light switch?
Aug 2, 2018 at 7:37 AM
