Yes, it does appear to be moving normally. I did notice what appears to be a loose retainer where it connects to the range sensor shaft. Did you notice it?
Well, the next questions will seem very general, but I need to confirm. When you shift the gears, does the gear indicator in the vehicle change correctly? Also, is the transmission fluid clean and full?
If the fluid is full, and the shift indicator is accurate, it could be a line pressure issue. Is this transmission original with the 200K+ miles? Has the filter been replaced on a scheduled basis?
I need you to check something. I need to know which model transmission you have. There are three optional automatics used on this vehicle, a 4L60E, 6L50, or an Allison transmission. I attached a couple of pics below to help you locate the info I need.
Let me know what you find.
See pics below.
Jul 3, 2022 at 8:12 PM
