No, there is no lubricating the cable. If it is stiff, it will need to be replaced.
REMOVAL
1. Loosen set screw (2) and remove knob (1) from shifter handle.
2. Remove the center console assembly (1).
3. Remove shifter bezel (1).
4. Disconnect shift cable (3) from shifter mechanism (1).
5. Remove three grommet plate to floor pan nuts as shown in.
6. Remove air cleaner assembly (1).
7. Disconnect both battery cables, remove battery hold down clamp and bolt, and remove battery (1).
8. Remove battery tray (1) from bracket.
9. Disconnect shifter cable (2) from shift lever (1) and remove from bracket.
10. Raise vehicle on hoist.
11. Remove catalytic converter heat shield (1).
12. Remove remaining grommet plate (1) screw and remove cable assembly (2) from vehicle.
Aug 22, 2019 at 1:26 PM
