Loose shifter
1992 JEEP GRAND CHEROKEE LAREDO
300,000 MILES • 4.0L • 6 CYL • 2WD • MANUAL
BRIAN ANTHONY MCLELLAN SR.
Gear shifter is very loose and wobble when engaged in any gear...
Jan 8, 2020 at 4:11 PM
94 TRANSAM
  • 680 POSTS
This is very common with older vehicles. Over time the shift linkage wears out as well as the shift forks in the transmission. It is not a cheap or easy fix, so unless you are having issues with it going into gear or popping out of gear you probably dont want to deal with it.
The solution is a trans overhaul and a new shifter if that is worn out too.
Rich
Jan 8, 2020 at 9:44 PM
