shift manually
1994 CHEVROLET S-10
160,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
MITCH DEVEREAUX
4l60e in limp mode second and drive, no low or overdrive. is it possible to disconnect comp. and shift manually?
May 21, 2021 at 12:04 AM
Good morning,
No, it cannot be disconnected since it is controlled by the ECM.
You most likely have a valve body issue in the transmission. I would start by changing the fluid and filter and see if there is any metal in the bottom of the pan.
https://www.2carpros.com/articles/automatic-transmission-problems
May 21, 2021 at 1:46 AM
