Shifter stuck in park. Got it towed a while back, tow truck guy found the override I however can not locate said override to get it into neutral. Need to do the crankshaft position sensor replacement which requires removing all pulleys and belts. No obvious shift lock override slot anywhere on top of shifting block. Help?
Jun 28, 2020 at 11:06 AM
