Shift lights and heating and air control lighting
2004 INFINITI QX56
222,000 MILES • V8 • 4WD
ROBERT SWAN
  • 8 POSTS
I no longer have back lighting for my shift controller or my heating and air controller system. I want to know if this is a fuse or a light bulb problem? And the simplest way to repair them.
Feb 12, 2018 at 10:10 AM
Yes there are four fuses that runt the system we should check first. Here is a guide to help you see what you are doing. Check # 59, 37, 36, 19, and 14.
Here are the interior illumination wiring diagrams so you can see how the system works and the fuse panel locations.
Check out the diagrams (below).
Feb 13, 2018 at 11:35 AM
