When I start up when it is cold the shift light flashes the tachometer jumps and engine runs rough. Like the timing is off. I have set timing and checked it 3 times. When the engine warms up the shift light quit flashing and tach quits jumping. Idles good but I still don’t think it running as good as it should like the timing control doesn’t work like it should unless you are running over 2,500 RPMs. I have replaced ground wires from cab to frame to engine. And checked every other ground wire on engine. I have replaced O2 sensor. New distributor complete. Coil plugs wires. I have a ESC box on the intake but I haven’t changed it yet. Just trying to see what direction to go from here?
Feb 6, 2021 at 6:51 AM
