Shaking while braking from 45-55 MPH?
2003 GMC SIERRA
250,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
JACOB MARINO
  • 45 POSTS
My truck shakes when I brake from high speeds. Specifically, 45-55 MPH but less violent shakes at other speeds. It doesn't happen while accelerating, so I ruled imbalanced/misaligned tires out. My rears are squeaking at me I believe it is just the brake pads needing replaced (correct me if I am wrong about that please) but also my brake pedal pulses when I push the brakes. Not all the time, but especially coming to a stop at slow speeds. Warped rotors?
May 30, 2023 at 3:01 AM
Yep, you are probably correct though tie rod ends can cause this as well.
Here is a guide to help you see what's going on:
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
and
https://www.2carpros.com/articles/a-deep-dive-into-resolving-shaking-steering-wheel-when-braking
Here is how to change the brake rotors and pads out in the video below:
https://youtu.be/9pwFodKAl5A
Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
May 30, 2023 at 5:59 PM
JACOB MARINO
  • 45 POSTS
So, I drove it around today without changing anything out yet and the noise stopped. I can't hear it anymore. Is it possible that the speaking was just thin rust buildup scraping away? It has been raining over here quite often recently. As for the shaking, I will check out the rotors and tie rods.
May 30, 2023 at 6:07 PM
Yes, this is very possible. The rust could be getting cleaned off of the brake rotors which is common. Use 2CarPros anytime, we are here to help. Please tell a friend.
Jun 1, 2023 at 2:44 PM
