Shaking/vibration
1999 TOYOTA TACOMA
200,000 MILES • 3.4L • 6 CYL
WILL MEAD
Car shakes at 50 to 55 unless I accelerate not all the time though.
Jan 2, 2020 at 1:37 AM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave.
The first suspect with a speed specific vibration is the tires, I would begin with having the tires rotated and balanced. There are a few other things that can give us some clues to the problem. First question is does the steering wheel shake when this happens? If it does then here is our tutorial on steering wheel shake:
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
If you can perform these steps and let us know the results we will be happy to guide you further and thank you for using 2CarPros!
Jan 2, 2020 at 3:48 AM
WILL MEAD
No it's more like the whole truck starts vibrating. now there seems to be a very high pitch noise coming from the motor.
Jan 11, 2020 at 2:48 AM
This sounds like a tire issue like one of them is coming apart. I would jack up each end of the car (one at a time) and roll the tires to looks for imperfections. here is a guide to help you:
Jan 13, 2020 at 1:45 PM
