Car started to shake in drive only in idle. it doesn't happen in neutral reverse or park. Also, when braking almost at a full stop it will surge slightly, shake then continue to shake in drive. This issue is intermittent. Sometimes you can shut car off and turn back on and it goes away. I can give It gas redline 1 gear and it goes away for a little or reduces amount of vibration. There are times where it will be dead still for day or two then happen again. It's a weird issue. The doesn't vibrate at all in park, reverse or neutral. No check engine light. Bank 1 fuel trim long and short is under +1.9 to +5.1 bank 2 is +3.9 to +6.2 sometimes both banks are 0 to 1.9 combined all 4. Mass air flow is 7gram in idle. Tps 1.2 to 1.6% Idle. note I took off air box and reinstall and went away but comes back. Smoke testing showed no leaks. Coils, wires and plugs are new. Graphed tps when driving and no dead spots. Only thing I found is bank 2 ltft is high compared to bank 1. I'm at a lost what I can be. Hoping someone can help me out .
Nov 1, 2021 at 3:56 AM
