Shaking from front driver side
2001 BUICK CENTURY
190,000 MILES • 3.1L • 2WD • AUTOMATIC
NATOCKA
  • 5 POSTS
I had inner and outer tire rods replaced but vibration still present. Mechanic told me motor mounts so I had motor and trans mount changed. Vibration and shaking still on driver side especially when I turn into a curb. What would you say the problem is?
Jul 11, 2019 at 5:12 PM
Good evening,
Did anyone check the axle shaft? If you have a bad CV joint it will vibrate.
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
https://www.2carpros.com/articles/replace-cv-axle
Also, did they check the strut to see if it is worn out and not keeping the suspension solid?
https://www.2carpros.com/articles/popping-noise
Jul 11, 2019 at 6:42 PM
NATOCKA
  • 5 POSTS
Good morning Roy!
I had the struts replaced last year so I will get them to check the CV axles. I think that's what it is also. Thanks!
Jul 12, 2019 at 5:28 AM
You are welcome.
Always glad to help.
Keep us updated.
Jul 12, 2019 at 5:53 AM
NATOCKA
  • 5 POSTS
Will do! Thanks!
Jul 12, 2019 at 11:18 AM
Any update?
Jul 12, 2019 at 2:53 PM
NATOCKA
  • 5 POSTS
No update yet! I have to take it on Monday but I will let you know.
Jul 12, 2019 at 6:07 PM
Sounds like a plan.
Jul 12, 2019 at 6:09 PM
NATOCKA
  • 5 POSTS
Evening!
Update-I had my car checked out today and it is the cv axle. So I'm going to order both and get them changed out.
Thanks for your time and information!
Jul 17, 2019 at 8:05 PM
You are welcome.
Jul 17, 2019 at 9:10 PM
