This could possibly be a couple of things. It could be your tires are out of balance or it could be a bad wheel bearing. To check to see if it is your vehicle's tires out of balance, just take them to where you purchased them and have them re-balance them. To check to see if it is a wheel bearing jack your vehicle up like you are going to change a front tire. Here is a link if you are unfamiliar with how to do it:
Next, go to the tire you want the wheel bearing on and try to move the top of the tire towards the vehicle and then the bottom of the tire away from the vehicle. There should be no play at all. If there is then the wheel bearing is bad and needs to be replaced. Please check your vehicle's tires and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Jul 6, 2019 at 12:09 PM
