I have the car listed above that ran fine. The ESC light was on. But ran fine, all of a sudden it starts to run very badly, bogged down, shaky, and decreased speed/engine power..still will get up to speed but takes forever. got one of those fixed sensor things you plug into car. It threw codes for 3 injectors. mechanic says he replaced all 6 ,still ran the same. Checked catalytic converter and muffler they're okay, another code was PCV. replaced the purge control valve still the same. other code was ECM he says not sure don't want to change because they would have to send to be reprogrammed and if it's not that then the money was wasted on that. Mechanic says checked coil packs. It's been 2 weeks now. Still not running right. I have no other car to drive. When all this started happening it also said on dash ESC and service traction control. help I'm broke and can't afford to take anywhere else now. I'm at around $500.00 with them so far.
Sep 1, 2020 at 7:49 AM
