Shakes
2002 MITSUBISHI DIAMANTE
162,000 MILES • 3.1L • 6 CYL • AUTOMATIC
JILL BARNES
My car did not shake at all until I had the donut replaced on the left front side with a used tire. The donut had only been on for three days. But my car shakes now on the right front side. What do you think the problem could be? Tire man says all the other tires look good.
Aug 27, 2017 at 9:15 PM
HARRY P
  • 2,292 POSTS
Does the car pull one way or the other? If so, then you need an alignment. If not, then you probably just need to get your wheels balanced. Either way it's not an expensive thing. Do make sure that your lug nuts are tight enough, because sometimes the tire people make mistakes and don't tighten them up all the way.
Aug 28, 2017 at 3:01 PM
STEVE W.
  • 15,113 POSTS
Swap the front/rear tires. Does it still shake up front? If not then try to balance them. It's possible that the tire threw a weight while you had the spare on.
If it still shakes then it is probably brake or axle related.
Aug 28, 2017 at 8:09 PM
