Sh-awd light turns on and off
2006 ACURA RL
148,000 MILES • 2.5L • V6 • 4WD • AUTOMATIC
ROB 1503
  • 63 POSTS
Does anyone know what can be causing the sh-awd light to turn on and off frequently? It started right after getting the power steering pump replaced.
Dec 23, 2018 at 8:26 AM
It sounds like the two are not related, but you never know. lets run the codes for the ABS. here is a video to show you how. I think you have a front bear hub going out which will make the ABS sensor work and then not causing the light to come on.
https://youtu.be/rTtAnsOlZU4
If so here is the step by step on how to change it out with diagrams below to show you on your car:
https://www.2carpros.com/articles/bearing-hub-replacement
Dec 25, 2018 at 2:52 PM
