I have the vehicle listed above with a 1.5l engine, and I'm having a bad hesitation in the throttle. This is what I've done and know as of now:
Good battery
New TPS
Cleaned IAC
Cleaned throttle body
New PCV Valve
New VVT Solenoid (has power)
Both up/down stream sensors new
New MAF Sensor
New Air Filter
No vacuum leaks at all
New Coils
New spark plugs
New fuel pump
New injectors with all seals
New damper pulsation damper
If I give it a little throttle and ease into the throttle it will go on down the road, if I go 1/2 throttle it falls on its face, if I push it all the way to the floor it will pick up and take off. Also sprayed the entire motor, vacuum hoses, intake manifold, breather box with brake cleaner no lacks.
Good battery
New TPS
Cleaned IAC
New PCV Valve
New MAF Sensor
New Air Filter
New Coils
New spark plugs
New fuel pump
Dec 20, 2024 at 2:38 AM
