Several turbo trouble codes?
2013 BMW 328
149,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
Car drives fine but i get the drivetrain malfunction message keeps popping up, but no effect on how it drives.
Oct 15, 2022 at 7:25 PM
Yep, the wastegate code should affect the engine power but it looks like it is not working. I would check the vacuum lines to the valve and if okay, replace the wastegate. Here are the instructions in the images below. Also check the actuator control solenoid. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem.
Oct 16, 2022 at 11:34 AM
BHAMDOC1973
  • 2,008 POSTS
All good after replacing the valve cover, but all these codes went away and a p1290 popped up, it never ends. Replaced the sensor even though there shouldn't be an issue with it all of a sudden. Engine coolant reads fine on scanner. Connector looks good. Same thing and it's always accompanied by a drive malfunction message, but no limp mode. Read few people changed sensor and all was good, of course that cannot happened to me, lol.
Oct 28, 2022 at 3:12 PM
BHAMDOC1973
  • 2,008 POSTS
All good after replacing the valve cover, but all these codes went away and a p1290 popped up, it never ends. Replaced the sensor even though there shouldn't be an issue with it all of a sudden. Engine coolant reads fine on scanner. Connector looks good. Same thing and it's always accompanied by a drive malfunction message, but no limp mode. Read few people changed sensor and all was good, of course that cannot happen to me lol. I replaced the coolant temperature sensor even though it called for cylinder head temperature sensor cause that's what i found in stores and it matches 100%.
Oct 28, 2022 at 3:19 PM
Glad we got the fist problem solved. Please post your new question here, you must be logged in.
Oct 29, 2022 at 2:31 PM
BHAMDOC1973
  • 2,008 POSTS
I didn't mean it was solved, i mean i still have p1290.
Oct 29, 2022 at 3:13 PM
BHAMDOC1973
  • 2,008 POSTS
Is this what reads the coolant temperature? Was not there before i changed valve cover.
Oct 29, 2022 at 3:23 PM
Yes, that is the coolant temperature sensor. Did you change out the turbo? They go bad all the time in these cars.
Oct 31, 2022 at 11:30 AM
BHAMDOC1973
  • 2,008 POSTS
I just adjusted the rod length on the turbo actuator and message went away was too loose.
Oct 31, 2022 at 11:34 AM
Nice work, we are here to help, please use 2CarPros anytime.
Nov 1, 2022 at 11:30 AM
