Codes P0223 and C1130, engine knocking noise while driving?
2010 NISSAN MURANO
197,000 MILES • 3.6L • V6 • 4WD • AUTOMATIC
JESSICAB0628
  • 4 POSTS
My vehicle listed above was driving fine, a little loud but okay, then it started knocking really bad as I was getting off the highway, pulled over, went home by rt6 instead of highway in case I needed to stop. I got home fine, but it was sputtering every time I excelled the gas, and the knocking was still bad! I looked under the hood next day in light and the pendulum mount was busted so that was the knocking and although I thought initially fuel injectors. I tried changing spark plugs 1st, and put fuel injector cleaner in the gas tank, after plugs changed it ran a little better, but still hesitated when excelling, take your foot off the gas and go again and it was getting better. I figured I will change the fuel injectors anyway so it's faster. I did that and noticed an oil leak, so I changed the intake manifold gasket, valve cover gaskets, and the oil cooler gasket. I also changed the battery about a week before this happened. Get it all back together start it up, and although it's still loud it sounded better plugged the obd2 back in and got cylinder 2 misfire again, multiple cylinder misfire, throttle position sensor to high, and the c1130 code. I am now at a loss, I don't know what else to do at this point please help! I don't know it I may have not plugged something in correctly, or what, but as far as I can see now there are no leaks, and it all looks sealed properly, I'm beginning to think that loud noise under the hood may be more than just a hole in the exhaust.
Jun 13, 2023 at 2:06 AM
BORIS K
  • 836 POSTS
Fault code C1130 is usually a resultant code of an engine P-code.
C1130
When diagnosing for DTC C1130 (ENGINE SIGNAL): ECM related DTCs (P-codes)
must be diagnosed, repaired, and DTCs erased first.
DTC C1130 is an ABS DTC that indicates an output signal of the ECM is not
recognized.
Absent or incorrect ECM signals, which are indicated by corresponding P-codes, may
trigger C1130 in the ABS unit.
Some vehicle features that can be affected by absent or incorrect ECM signals are:
Forward Emergency Braking (FEB)
Intelligent Cruise Control (ICC)
VDC/ABS/TCS
A short video
https://youtu.be/XY2O6NMCI90
So, we need to first diagnose the misfire fault and TB fault P0223.
Misfires can be caused by bad compression, intake air leaks, low fuel pressure, bad spark plugs, bad ignition coils, bad injectors, low charge voltage to name but a few
As you have replaced the injectors, spark plugs and intake manifold gasket we can tick off a few items but the issue on cylinder 2 has not been solved.
A good video
https://youtu.be/e3YCZa2Ygpo
First, I would suggest to cross swap the ignition coil from a known good cylinder.
Start engine after swap and see if misfire moves to the other cylinder.
If the misfire is still on cylinder 2 next check for possible air leaks.
Ideally this is done using a smoke tester, but you can use a can of carburetor cleaner/easy start. Start the engine and carefully spray around the intake manifold, injectors and vacuum pipes. Listen if the engine running changes
A video:
https://youtu.be/xN5pcM-5bso
and
https://youtu.be/BQUWXYJojUY
If nothing has been found next I would suggest to carry out a compression test
How to:
https://youtu.be/J3j85hg0d-4
The above tests for the misfire should yield some results.
P0223
An excessively high voltage from the Throttle Position Sensor (TPS) 2 is sent to Engine Control Module (ECM).
Possible causes
Faulty Throttle position sensor
Throttle position sensor harness is open or shorted
Throttle position sensor poor electrical connection
Faulty accelerator pedal position sensor
I would suggest to first check the condition of the TB connector.
Check that there is no corrosion/widened pins in the connector
If in order next check the wiring back from the TB to the ECM.
See image 1+2
Pin out at the TB and ECM connector F8
Pin 1, green wire to ECM pin 47
Pin 2, white wire to ECM pin 37
Pin 3, red wire to ECM pin 38
Pin 4, black wire to ECM pin 36
Pin out acc pedal to ECM connector E16
Pin 1, green wire to ECM pin 100
Pin 2, black wire to ECM pin 84
Pin 3, white wire to ECM pin 81
Pin 4, brown wire to ECM pin 83
Pin 5, grey wire to ECM pin 87
Pin 6, orange wire to ECM pin 82
See image 3+4 below
How to test wire:
How to use voltmeter:
Please let us know if you need any other information.
Cheers, Boris
Jun 13, 2023 at 3:54 AM
JESSICAB0628
  • 4 POSTS
I fixed all that, dotted i's crossed t's, it's running no lights, but took it for a drive and there is a smell I'm assuming all the fluids burning off the engine, but when accelerating the rpms are going up higher than usual when shifting gears.
Jun 20, 2023 at 11:51 PM
JESSICAB0628
  • 4 POSTS
Never mind, shut it off then tried to restart it, and it now won't start up! It's a push button so when you press the start button and the breaking just keeps making sounds like it's going to start but does not.
Jun 20, 2023 at 11:54 PM
BORIS K
  • 836 POSTS
I would suggest you check battery terminals, starter connections and engine ground wires first.
Your vehicle is fitted with the XTronic CVT transmission. Issues with these can cause higher rpm in gears and possible burning smells
I would suggest checking the transmission oil level first.
How to:
https://youtu.be/qgb_ArjfWqA
Cheers, Boris
Jun 21, 2023 at 9:22 AM
