How does the engine sounds while cranking over? can you upload short video so I can tell if the engine is any good or not? It time again for a donation btw :)
https://gofund.me/c7d318ad
P017C - Cylinder Head Temperature (CHT) Sensor - circuit low
P13C7 - Knock Sensor 2, “Electrical Signal Input B Short Circuit To Ground”
P328 / P1328 These are more opaque - could relate to camshaft / VANOS / variable valve timing circuits
P13B8, P13AE, P13A3, P13BE
All “P13xx” codes often involve camshaft sensor, knock sensor, or VANOS / variable valvetrain
P10D6 Might relate to ignition - misfire or a more specific BMW module fault (less commonly seen in generic lists)
It seems like it can have a broken timing chain, once I hear the engine cranking I can tell for sure or you can do a compression test which will tell us as well.
https://www.youtube.com/watch?v=KOxIm1F8AW0&pp=0gcJCfYJAYcqIYzv
Let us know how it goes.
Sep 27, 2025 at 11:45 AM
