Okay, I'm assuming you got a cap from the dealership. I'm looking at these 2.3Liters and there's two different engines for this model, what Sub-model is this, or if you know which engine is in this vehicle, for Sub-models I've got listed s Grand Touring, s Sport, s Touring and these have the 2.3liter CD L3V engine,
And the other 2.3 is the MazdaSpeed which has a 2.3Liter CD L3 engine. And a Hatchback or Sedan option as well. or I can go by the Vin # if you have that.
I'm only asking because there seems to be a different code setting criteria for the different engines and sub-models.
For instance, below is some of the differences it is asking me just for that particular code.
These are Direct Injection setups where we'll have up to almost 2000psi fuel pressure, so that's probably why it's asking about different models.
And are you getting a voltage reading (PID) for that Front Oxygen sensor, anything lower than 1.8volts on the Live Data stream? and can you see if there is any Freeze Frame Data for that code?
Go ahead and take a really good look at the connector for the front oxygen sensor. Make sure there's no loose pin fitment or any harness issues there, because it can be reading low voltage for a number of reasons, just want to rule out any open circuit issues, etc., to begin with.
And sorry about all the questions, but is this a California car? The emissions standards are different, and it looks like the actual wiring of the front Oxygen sensor may be different as well.
Hopefully, this is just a bad front 02, but it's odd that the code changed from no activity to low voltage. Did the dealership do any work on this, or did you change the cap?
Jan 28, 2022 at 2:44 PM
