Good morning,
I posted below the procedure and torque for the rocker arm bolts for you. There is no sequence but it is best to roll the motor to where the intake and exhaust valves are both closed to do a proper adjustment.
INSTALLATION
1. Lubricate tappets.
2. Install tappets and push rods in their original positions. Ensure that the oil feed hole in the side of the tappet body faces up (away from the crankshaft).
3. Install aligning yokes with ARROW toward camshaft.
4. Install yoke retainer. Tighten the bolts to 23 Nm (200 in. lbs.) torque. Install intake manifold.
5. Install push rods in original positions.
6. Install rocker arms.
7. Install cylinder head cover.
8. Install air cleaner assembly and air inlet hose.
9. Start and operate engine. Warm up to normal operating temperature.
Feb 8, 2019 at 1:36 AM
