Ses light: code p0717 speed sensor input/turbine
1996 CADILLAC DEVILLE
110,250 MILES
NEPDABOSS1991
  • 10 POSTS
Speed sensor bad speedo still works and trans also shifts fine. Anyway to clear this or how do i go about changing it? I believe that it is interal transmission.
Should i change the sensor change tranny or get rebuild?
May 15, 2013 at 11:06 AM
HMAC300
  • 48,601 POSTS
that is a sensor in the trans sounds like it's slipping, etc. have a trans guy give you a better opinion.
May 15, 2013 at 12:04 PM
NEPDABOSS1991
  • 10 POSTS
No theres no slipping at all
May 15, 2013 at 12:06 PM
HMAC300
  • 48,601 POSTS
something is wrong because it set a code it may have lost overdrive or something you have noticed yet.
May 15, 2013 at 12:25 PM
NEPDABOSS1991
  • 10 POSTS
I feel it change 3 times
May 30, 2013 at 4:55 PM
HMAC300
  • 48,601 POSTS
have a trans guy look at this you won't feel the torque converter clutch kick in only shift 3 times.
May 30, 2013 at 7:36 PM
