This causes the rear brakes to close as if the parking brake was engaged their is an override button to bypass stability control that only worked once I have disconnected the battery to reset it did help but problem returned. I have checked all fuses they check out ok, I was told to replace the ALC automatic leveling control relay but I just cannot seem to locate in the engine compartment I looked for it in the fuse box in the engine compartment no luck, I also checked for air leaks I cannot hear any air escaping from air lines leading to air shocks
Jorge
Jorge
Sep 15, 2014 at 3:27 PM
