Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
GMC
Yukon
Suspension
Sway Bar
Replace/Remove
Service stability
2004 GMC YUKON
173,000 MILES • 4WD
LIBO
MEMBER
1 POST
FOLLOW
I am replacing the wheel bearing column and now shows the light service stability on.
Jan 25, 2018 at 4:33 AM
CERTIFIED EXPERT
It sounds like you have a defective wheel bearing hub or you forgot to plug the ABS wheel sensor in. Can you please double check for me?
Jan 26, 2018 at 10:33 AM
