Service Ride Control, code RS0061
1996 CADILLAC ELDORADO
99,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
19SILVER67
  • 4 POSTS
The service ride control is on and the code (RS0061 current) appears. From what I've read so far this is the right front suspension height sensor. Does this mean the sensor is automatically bad ? What is the first step in correcting this problem? Thanks for any information!
Aug 10, 2019 at 10:12 AM
Normally this is the sensor but there is a test attached that will get you to the correct issue. Let me know if you have questions but this will require you to perform some electrical testing. Here is a guide that helps explain this type of testing in case you are not familiar:
Aug 11, 2019 at 8:08 AM
19SILVER67
  • 4 POSTS
Hello, this is exactly what I was looking for to try and fix this issue. I appreciate your help!
Aug 12, 2019 at 5:47 PM
You are welcome. Please come back and use 2CarPros again in the future. Thanks
Aug 12, 2019 at 6:03 PM
