Turn Off the Ignition: Make sure the vehicle is turned off.
Press and Hold the Trip Meter Reset Button: Locate the trip meter reset button, usually found on the dashboard beside the speedometer.
Turn the Ignition On: Turn the ignition key to the "ON" position, but do not start the engine.
Continue Holding the Button: Keep holding the trip meter reset button for about 10 seconds.
Service Light Should Reset: The display should flash, or a beep may sound, indicating that the service light has been reset.
Release the Button and Start the Engine: Release the trip meter button and start the engine to ensure that the service light does not appear again.
May 12, 2024 at 7:13 PM
