Service light
1992 CHEVROLET CAMARO
118,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
SONNYBEE
The sevice light stays on as it warms up goes away then comes back on again and does the same thing over again.
Mar 30, 2020 at 7:08 PM
What I need you to do is check for diagnostic trouble codes. The code or codes will point us in the right direction of the problem.
Now, this is an OBD1 system. You don't need a scanner to get codes. All you will need is a short jumper wire or even a paper clip. Here is a link that explains how it is done. Take a look through it and follow the directions to get the codes. Once you get them, let me know what they are and I'll help direct you.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Let me know what you find.
Mar 30, 2020 at 8:24 PM
