Service engine light on
1993 VOLVO 940
225,000 MILES • 3.4L • 4 CYL • 2WD • AUTOMATIC
GOJOE
What does it mean when this light goes on?
Mar 12, 2019 at 11:37 AM
D6SPAN
  • 58 POSTS
Hi Gojoe,
Most of the time it means that you have an engine code. You can visit one of your local parts houses and they will check the codes for free. On newer vehicles, it often just means that the oil needs to be changed.
Mar 12, 2019 at 3:45 PM
Good evening,
Just to add to the previous answer, the check engine light means there is a fault in the fuel control system. When there is a fault, the light will come on and set a code. When it is retrieved, we can narrow the area of failure for you.
A parts store will read it for free. Get back to us with the information and we can continue to help.
Mar 12, 2019 at 4:08 PM
