Serpentine belt
1990 MITSUBISHI ECLIPSE
162,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
PATRICIA WHITE
What is the length of my what is the length of my serpentine belt?
May 15, 2017 at 12:49 AM
STEVE W.
  • 15,113 POSTS
Well it looks like you have a few options as it uses multiple belts. If you have one belt that is failing you would be better off changing all three just to avoid trouble from the ones you did not replace.
Length wise the belt that drives the AC (6) is 945mm long the one that drives the alternator and water pump (3) is 990mm long. The V belt that drives the power steering (4) is 673mm.
May 15, 2017 at 4:41 AM
