Serpentine belt squealing after change
2000 NISSAN MAXIMA
105,000 MILES • 2.0L • V6 • 2WD • AUTOMATIC
CHRISTIANMJ
Alternator light came on last night. Took a chance and drove the car home with it on (for about twenty minutes). Found the serpentine belt shredded this morning. Got a mechanic to come change it and now it is squealing loudly. Squeal goes away with water for a few seconds. The mechanic says the alternator is getting really hot and that the alternator may need changing. Could it be that the alternator is overworking to recharge the battery? The alignment looks good and I hope the tension is good as well. The mechanic said the tension is good. Is it safe to drive the car with it squealing like that?
Nov 25, 2017 at 11:03 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
It sounds to me as though the front or rear bearing in the alternator is bad, thus the reason for the noise as well as the heat.
Nov 25, 2017 at 12:06 PM
