Serpentine belt tension adjustment
2003 PONTIAC MONTANA
184,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
BILLHENDLER
  • 4 POSTS
I replaced the serpentine belt and it is in properly but I had to pry it on and the tension arm is bottomed out with no resistance left on the arm. This seems extremely tight. I have double checked the length and part number and everything is correct,I attempted to loosen the alternator to give it a little less tension but couldn't figure out how to do it. Is there any way to get some slack in it?
Apr 1, 2020 at 10:57 AM
Good afternoon,
No, there is no way to get more slack.
Are you sure it is routed correctly? I attached a picture of the routing.
If it is correct, you have the wrong belt.
Apr 1, 2020 at 12:33 PM
BILLHENDLER
  • 4 POSTS
checked part number, checked routing, test drove it 4 mile and now the belt has relaxed a bit. Thanks
Apr 1, 2020 at 1:12 PM
You are welcome.
Always glad to help.
Apr 1, 2020 at 1:15 PM
