imma cj guy, i do know some stuff about installing belts
ok, i do not know your rig.......but i am assuming you have a spring loaded tensioner....as most newer rigs do........(my dad's '86 t-bird is mechanically tightened)
i use a breaker bar (pull handle) in most cases
sometimes you just cannot get it to fit the nut.....needing just a hair more "twist" to engage the socket,
what i do in such cases is, lever the pulley itself with a handle/board/rod/etc.......just enough to get my socket on
be very careful------do not "fulcrum" (lever) against your radiator inlet or other stuff that will break!!!!!!!!!!
respond with wonderful news!
the medic
Jul 16, 2020 at 11:24 AM
(Merged)
