Serpentine belt replacement
2017 HYUNDAI ELANTRA
103,800 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
ARKMAN8208
  • 5 POSTS
Hi, I have the car listed above SE model and I'm trying to replace the serpentine belt as part of the 100,000 maintenance for the car. I know where the tensioner is and which way to rotate it but it refuses to budge. Any thoughts?
Jan 25, 2021 at 8:53 AM
Take a look through these directions and let me know if this is how you are doing it.
____________________________________________
2017 Hyundai Elantra (AD) VIN KMH L4-2.0L
Drive Belt - Repair Procedures
Vehicle Engine, Cooling and Exhaust Engine Drive Belts, Mounts, Brackets and Accessories Drive Belt Service and Repair Procedures Drive Belt - Repair Procedures
DRIVE BELT - REPAIR PROCEDURES
Removal
Remove the drive belt.
Using the wrench, turning the drive belt tensioner (A) counterclockwise.
pic 1
Disconnect the drive belt (A).
pic 2
Remove the drive belt tensioner (A) and then remove the drive belt (B).
pic 3
Jan 25, 2021 at 7:07 PM
ARKMAN8208
  • 5 POSTS
Yep except the tensioner won't budge at all.
Jan 26, 2021 at 2:39 PM
If it is locked, it will need to be replaced. Since the belt may be too tight to get off, you may need to cut it off.
Here are directions for replacing the tensioner. The attached pic correlates with the directions.
Drive Belt Tensioner - Repair Procedures
Vehicle Engine, Cooling and Exhaust Engine Drive Belts, Mounts, Brackets and Accessories Drive Belt Tensioner Service and Repair Procedures Drive Belt Tensioner - Repair Procedures
DRIVE BELT TENSIONER - REPAIR PROCEDURES
Removal and Installation
Disconnect the drive belt.
(You may need to cut your belt off)
Remove the drive belt tensioner (A).
Tightening torque :
center bolt :
29.4 - 41.2 N.m (3.0 - 4.2 kgf.m, 21.7 - 30.4 lb-ft)
fxing bolt :
39.2 - 49.0 N.m (4.0 - 5.0 kgf.m, 28.9 - 36.2 lb-ft)
pic 1
Install in the reverse order of removal.
Let me know if this helps or if you have questions.
Jan 26, 2021 at 3:13 PM
ARKMAN8208
  • 5 POSTS
So the one in the center is like a star and then the bolt to the left both have to come off. correct?
Jan 27, 2021 at 6:09 AM
Yes. They both need to be removed. I believe the one in the middle is a reverse torx.
Let me know if you get it off.
Jan 27, 2021 at 5:10 PM
ARKMAN8208
  • 5 POSTS
Will do, thank you.
Jan 28, 2021 at 1:40 AM
You are very welcome. Let me know how things turn out for you or if you have questions or need help.
Jan 28, 2021 at 4:21 PM
