Jumping off a pulley, jumping off-center to one side, or just vibrating a lot? A lot of vibration suggests one pulley is tight and doesn't want to rotate. Squealing means the belt is sliding across one of the smooth pulleys as it goes around it. That is caused by that pulley, or the one right before it being tipped or turned. The spring-loaded tensioner pulley is a common cause and a good guess for that, but also look at any other idler pulleys and the water pump pulley.
What is the condition of the belt? Do you see fraying and white strings peeking out on one edge? Has there been any kind of belt dressing applied to it?
Smooth metal pulleys were painted black at the factory. That paint wears off as the belt runs over that section. With the engine running, look for a pulley where the belt is running to the side of that shiny area now. That also indicates that pulley or the one just before it tipped or turned, usually due to a worn bearing. The pivot arm of the tensioner pulley can develop wear too and allow that pulley to droop and tip. Since it has been replaced already, check that it is mounted squarely. There's a tab on the back of the mounting plate that must sit in a hole to keep it from working loose and rotating. I've had a couple where I didn't get that tab seated correctly the first time.
Check out this article too for more information:
https://www.2carpros.com/articles/car-squeaking-noise
Let me know what you find.
Apr 11, 2023 at 5:28 PM
