I’ve been dealing with my belt making noise on cold startup until the engine warms up a little for couple of years now. I’ve changed multiple parts on it and it’s always a temporary fix. I changed the belt tensioner twice, upper and lower idler pulleys 3 times, and the drive belt multiple times. I have used both OEM and aftermarket times and it still hasn’t fixed the issue. I checked all the pulleys for play or any noise and they are quiet. I had a Mercedes specialist also look at it and they could find anything wrong and therefore recommended a new belt. I bought the Mercedes belt and installed it and there was no noise for about 1,000 miles but then after that it started again. It also does it when I do a cold startup and until the engine warms up a little bit because after that then it’s completely quiet. There was 2 TSB’s issued for this issue in the M272 engine and I followed both of them. One of them was to apply a krytox lubricant on the edge of the belt and run the engine. That quiets the belt down but after the lubricant wears off it starts making noise again. 2 weeks ago I had to change the thermostat, so I changed the oil filter housing gaskets and the upper coolant hose o ring because there was a seepage. After cleaning all the pulleys it got a little better but it’s still making quite a bit of noise. I don’t think there is pulley misalignments either because the noise stops after about 5 minutes of driving. Any suggestions?
Mar 27, 2025 at 11:26 PM
